TrevorK »
https://forums.nicoclub.com/trevork-u192129.html
Wed May 20, 2015 3:01 pm
To be honest, provided you have enough coolant, you have followed the proper procedure to refill the coolant (to bleed the air out) and you are not losing coolant, it sounds like the problem is related to the engine being overworked or the water pump.
You have eliminated (seemingly) many potential causes: lack of airflow to the radiator, damaged radiator fins, thermostat, clogged radiator, cooling fan. This leaves the major causes as the engine being overlooked and the waterpump/belt. An example of the engine being overworked would be driving in a low gear for long periods of time at higher speeds.
On this site is a factory service manual for your vehicle - if you download it there will be a list inside of what Nissan considers the possible causes. This can help you go through them. The fact that your overheating is tied to the physical speed you are travelling makes me wonder if something is causing the engine to work too hard (dragging brakes?).
