How about this one:
"..ALIGNMENT PROCESS
IMPORTANT:
Use only the alignment specifications listed in this Service Manual.
• When displaying the alignment settings, many alignment machines use “indicators”: (Green/red, plus or
minus, Go/No Go).
Do not use these indicators.
- The alignment specifications programmed into your machine that operate these indicators may not be correct.
- This may result in an ERROR.
• Some newer alignment machines are equipped with an “optional Rolling Compensation” method to “compensate”
the sensors (alignment targets or head units).
Do not use this “Rolling Compensation” method.
- Use the “Jacking Compensation Method”. After installing the alignment targets or head units, raise the vehicle
and rotate the wheels 1/2 turn both ways.
- See Instructions in the alignment machine you're using for more information on this...."
Do I have to inform alignment specialists about these requirements?
Wow!
I can imagine what they would say me in response!
