IM HAVING A HARD TIME TRYING TO FIGURE OUT WHAT YOUR CONCERN IS, AS ITS NOT REALLY IN ENGLISH LOL - BUT I TOOK A PHOTO FROM THE MANUAL AND COLOR CODED THE FLOW FOR YOU.jadue123 wrote:2011 rogue awd, does it have transmission cooler in front of radiator?
i checked today and saw one before radiator is this correct, reason for asking is because i saw couple tab are crused in starting at top and bottom, is this something to be concerned about?
ok, are you talking about this?jadue123 wrote:thanks see those black spot on the attachment
i have those tab not sure what there called are pitched
do oil go through that
i could not post picture
but i am taking about close to number 5 and 3
where is pinched
and you can start being more descriptive and concise by not writing run-on sentences.jadue123 wrote:thanks see those black spot on the attachment
where is pinched
IN YOUR 2011 YOU DONT HAVE A STAND ALONE TRANSMISSION COOLER OUTSIDE OF THE STANDARD ONE, ALL THE WAY ON THE BOTTOM OF THE RADIATOR.jadue123 wrote:2011 rogue awd, does it have transmission cooler in front of radiator?
wind passes through the fins, and cool the fins. the fins are between the channels that the fluid flows through.jadue123 wrote:yes i am talking about fins on transmission cooler. i do have cooler in front of condenser, and yes the fins are pressed on top left about 10 fins and same on right bottom. what are the fins for? is is for air or something else?
