2011 nissan rogue ac compressor
jadue123
Car: 2011 rogue
hi guys
i am new to this sight
i have 2011 nissan rogue sw, i bought it as rebuilt title so no warranty
my question is cable on ac compressor where does it come from, is not connected
also no plug hanging around for me plug it in
thx
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
jadue123 wrote:hi guys
thx
are you talking about the hose? or the wire?
TaiLuu
Car: 2009 Nissan Murano LE AWD
2011 Nissan Rogue SV AWD
2014 Nissan Pathfinder Platinum
If AC still works I wouldn't worry. If there is an extra connector then the Compressor is more than likely from another car like an Altima. Dual zone climate probably ?
ImStricken06
2016 Kia Sorento
TaiLuu wrote:If AC still works I wouldn't worry. If there is an extra connector then the Compressor is more than likely from another car like an Altima. Dual zone climate probably ?
dual zone is divided in the air box area under the dash.
if you want heat = you will have hot engine coolant enter into the heater core and air will be blown through the heater core and into the cabin.
if your passenger wants cool - the r-134a is compressed by the compressor and passed through the Condenser to cool and into the Evaporator where air is passed through, cooled and blown into the cabin.
ImStricken06
2016 Kia Sorento
I WENT OUT AND GRABBED AN A/C COMPRESSOR TO MAKE THIS EASIER.
WHICH LETTER ARE YOU TALKING ABOUT?
ImStricken06
2016 Kia Sorento
jadue123
Car: 2011 rogue
thanks guys
i found the cable but the plug that goes in compressor is broken
not sure if i can just buy the plug looking at the picture part c is broken
ImStricken06
2016 Kia Sorento
soldier the connections and fill it with RTV sealant
jadue123
Car: 2011 rogue
i will try that thanks
ImStricken06
2016 Kia Sorento
how did you make out? any luck?
jadue123
Car: 2011 rogue
i managed to joint the cable, but compressor not turning
i am waiting for the refill kit for ac
ImStricken06
2016 Kia Sorento
jadue123 wrote:i managed to joint the cable, but compressor not turning
keep us posted :)
jadue123
Car: 2011 rogue
did not work
trying to fine pressure switch plug
anyone have picture?hhhh
ImStricken06
2016 Kia Sorento
jadue123 wrote:did not work
In the diagram reference, the A/C pressure switch is number 9:
jadue123
Car: 2011 rogue
thanks strange i dont see any plug on top of 9
ImStricken06
2016 Kia Sorento
jadue123 wrote:thanks strange i dont see any plug on top of 9
TO TEST JUST THE AC PUMP/CLUTCH.
Take a piece of wire and connect one end to the +(plus) of the battery and the other end to the plug for the a/c compressor ( there's only one wire that goes to the compressor). Your basically jumping the compressor to see if it comes on. If it does place your can of r134 on there and charge it up. It should be fine after that.
1. If you jump the compressor and still does not turn on - its dead.
2. if you jumped 12v to the clutch and it came on and while on. you connected the r134 and charged it then reconnected the plug to the compressor and the ac still does not come on that means your hi/lo pressure switch on your receiver/dryer is bad.
TO TEST THE ELECTRICAL SYSTEM.
or VERY short periods of time you can check the compressor by bypassing this pressure switch (jump the 2 pins with a wire) and the compressor should kick on and run normally... dont do this for more than a minute or so though. cross the 2 prongs and the compressor thinks theres enough freon in the system and runs.
sorry its 9pm here in NJ, so my picture is dark
ImStricken06
2016 Kia Sorento
also have you checked your relay to make sure its on & working?
jadue123
Car: 2011 rogue
thanks i will try
no how do you check relay?
h
ImStricken06
2016 Kia Sorento
jadue123 wrote:thanks i will try
h
find a similar relay, and swap. does the part you swapped with still work? if yes = good.
jadue123
Car: 2011 rogue
is this under hood where fuses are?
ImStricken06
2016 Kia Sorento
jadue123 wrote:is this under hood where fuses are?
its gonna look like this
jadue123
Car: 2011 rogue
i found a plug with 3 wires white, blue and yellow.
problem is i can't fine any place this goes in.
ImStricken06
2016 Kia Sorento
jadue123 wrote:i found a plug with 3 wires white, blue and yellow.
picture of location of this wire? is it next to the left/driver headlight radiator area?
jadue123
Car: 2011 rogue
yes. it is close to where it should be driver side
ImStricken06
2016 Kia Sorento
jadue123 wrote:yes. it is close to where it should be driver side
check the picture i posted last night
jadue123
Car: 2011 rogue
yep same place
i guess i will have to buy the switch
jadue123
Car: 2011 rogue
ok replaced ac pressure switch, still no luck.
what voltage should be at compressor on those two wires plugs in compressor?
not getting any voltage at all
h
ImStricken06
2016 Kia Sorento
jadue123 wrote:ok replaced ac pressure switch, still no luck.
h
12volts. go directly to battery and try to run a wire to the ac pump itself.
jadue123
Car: 2011 rogue
do i need both negative also plugged in on compressor?
i tried just the positive on one of the pin no luck
Return to “Rogue Forum”
