2011 Nissan Quest intermittent power window driver side
A forum for the Nissan Quest... minivan lovers unite!
Mtylerkc
Car: Nissan Quest 2011
I have a Nissan quest 2011 and the driver side power window switch is intermittent. Sometimes it goes for several weeks working just fine and then it stops working for a day or two and then starts working again. I do not think it's the motor or regulator since the speed of the window is just fine. It doesn't seem to be slowing down at all just intermittently working. I'm wondering if it's the switch which seems to be easy to replace but before I do that I was looking for more information.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
Yes, it does sound like it is a faulty switch, there are a couple of used ones on ebay right now for around $40.
Mtylerkc
Thanks for your reply. That's what I was thinking. Will give it a try. Thanks for the ebay suggestion too.
far raf
Car: 2005 Nissan Quest SE (standard? simple? edition - i.e. nothing special)
Or you might try taking the switch apart and cleaning it, for example with the electric contact cleaner spray or finest sandpaper. But it's Nissan, there will be intermittent electrical problems anyway. That's how they make a living.
Mtylerkc
That's a great idea, going to try that! Thanks!!
far raf
If cleaning does not help, the only way to find out the root cause would be tracing with a multimeter to see where power goes cold.
Return to “Quest Forum”
