2011 NAD Re-Dipped Altima
General discussion area for the L32-chassis Altima
mrandersonz
Car: 2011 Nissan Altima 2.5S NAD
Sedan with 3.5 SR Additions .
Spoiler, Plasti-Dip Trim, upgraded Nissan Alloy Rims. 3.5 SR LED Mirrors
So, Let me just say that Plasti-Dipping is Awesome or so I thought in 2013 when I dipped my Altima for the first time!
I however didn't follow the basic rule! Use At Least 5-6 Coats of Dip! I used about 3 1/2.
Not good for the altima! ::( I thought that the coats looked thick enough so I stopped and thought I did an awesome job.
Fast forward to 2016, The dip has been chipping away at the Rims and the grill not to mention the trim around the windows.
Removing this dip was a pain in my .. anyways, It came down to using various products and sinking over $50+ into chemicals.
Wd-40, Brake Cleaner, ect.. Goof Off! This really sucked so I decided to re-dip the correct way. Observe.
Once I Stripped The Dip..
Side Shot.. Looks so different!
Grill
As you can see, I just wanted so baddly to Re-Dip my baby!
So, Before the sun got too hot I tapped this bad boy up and began to re-spray.
Then, The Window Trim
Check Out Part II
mrandersonz
Once the Painters Tape Removed...
I was so much more satisfied with the amount of coats I added.
Once I started to peel off the excess dip, it looked awesome!
mrandersonz
THE FINAL RESULT OF DIPPING!!
They say don't wash plasti-dip for about two weeks so i went to one of those self pressure wash car washes. holding it waay back so only aiming around the plasti-dip. And at the sun setting, this was my result...
Return to “4th Generation Altima Sedan (2007-2012)”
