2011 Maxima Power Steering Pressure Switch
johnramos
Car: 2011 Nissan Maxima
Can the actual pressure switch leak? I used Teflon Tape and a fresh O-ring afterwards and it still leaked. There's nothing above that point that can leak so it has me baffled. See Diagram: https://www.nissanpartsdeal.com/diagram ... 7_A002.png
Thanks
centralcoaster33
Car: 1997 Nissan 240SX #5
Could the leak be running along the hose line and be coming from above, like the fluid reservoir maybe? I don't know which number equals the sensor in your posted diagram.
Maxcruiser
Car: 01 Maxima
Have changed the belts lately?
A lot of Maxima owners don't agree with the p/s hoses needing to be removed from the pump before loosening the pump to put on the belt.
If you don't it puts a strain on the hoses could cause leakage.
Putting a strain on any crimped hose could cause it to leak.
I can vouch to this. It's happened to me.
The switch should have an o-ring. It's high pressure so I doubt Teflon tape will hold it off.
The 01 is over 1200 psi of pressure!
