At the dealer or another shop?Frog wrote:Well the M is now in the shop getting the timing chain done...
Nice! That's good news for me. Hopefully my dealer is as willing.Frog wrote:2011 m56s. 50,000 miles. Local Infiniti dealer. All I did was record the sound it makes at start up. A whine for about 15 Seconds, it's worse when cold. It's not bad. I sent that video to my service tech and he had the manager listen to it and they agreed time to replace.
The power train warrant is 6 years 70k I think
Thanks for the info on likely no oil leaks when done
It will ease that concern, but not the concern that evidently 5.6's are blowing timing chains left and right (and that one of our very own members who works for Infiniti is doing like 1 or 2 a week or whatever).CRV_33 wrote:Someone should go up to a local Infiniti dealership and have them do a cold start up on a new Q70 V8 on the dealers lot. See if it makes that sound initially, could definitely ease a lot of minds in this forum.
The chains are more likely to fail on a QX56/80. Our shop (me) has only done one set on an M56. NEVER once has a chain actually broke or ruined a motor. The noise they create is due to the passenger side chain stretching and rubbing the oil jet. Otherwise, the tensioner still keeps the chain right and the motor correctly in time. As far as the repair go and your concern for leaks, as previously mentioned, Infiniti sealant is some of the best stuff I've seen. From a repair standpoint, it's not a difficult job it's just time consuming. The only thing that needs to be re-sealed are the front timing cover and VTC covers. The oil pan doesn't even need to come off. The timing covers and VTC covers go back on perfectly, they have to align with the alignment dowels in the block, so it's not like it can be put back on crooked or anything. Even if there were no alignment dowels to center the cover, if it went on wrong none of the 32 bolts that hold it in place would line up appropriately.Ilya wrote:It will ease that concern, but not the concern that evidently 5.6's are blowing timing chains left and right (and that one of our very own members who works for Infiniti is doing like 1 or 2 a week or whatever).CRV_33 wrote:Someone should go up to a local Infiniti dealership and have them do a cold start up on a new Q70 V8 on the dealers lot. See if it makes that sound initially, could definitely ease a lot of minds in this forum.
That's my main concern. I just basically want to finagle my way into having the timing chain replaced regardless of the noise. That way I know, noise or not, that my chain won't grenade my motor in 20kmi.
Technically the FSM has you remove the intake manifold and valve covers to find TDC. I don't take them off, I can find TDC by the cam gear timing marks with the cover off. The oil pan has to come off on the QX's due to the design of the oil pump being driven directly off the crankshaft. The M's oil pump is chain driven off a sprocket on the crank and can be removed without pulling the pan. Once you do a couple you can learn little ways to make it easier to do. For example, the FSM states the engine and trans need to be removed on the JX35/QX60 to replace the transmission. I can replace the trans without pulling the motor which saves so much time. It may seem like it's cutting corners, but in my opinion, the less intrusive I have to be on a car to get a job done is actually better. The less stuff that has to be removed is better for the car.Ilya wrote:Let us know how it goes Deezy.
And Steve, so you don't need to remove the intake manifold, etc.? The video of the QX being worked on seemed like it was a lot more involved then just removing, say, the radiator and crap to get better room.
I can't say for certain, but I think the noise has something to do with the high pressure fuel pump, VVT, and open loop operation during warmup. Once the car goes closed loop and is using the air fuel sensors to adjust the air fuel ratio, the motor smooths out and the noise goes away. The 5.6 is a noisy motor, and every one I've seen has the same noise.Deezyweezy wrote:The tech I talked to suggested a noise that occurs at cold start, then goes away in less than a minute "may" be unrelated to the timing chain. I love the car, day three of ownership, but man the timing chain has me puckered! I'll keep you posted on my results and certainly let me know what you guys have seen.
My mentor when I was an apprentice would do chains on the QX56 without even removing the radiator. There's lots of different ways to do the job. I could do it without pulling the radiator as well, but the extra room to work is worth the time it takes to pull a few extra parts off.Ilya wrote:Let us know how it goes Deezy.
The beginning symptom is a very high pitched whine noise when lightly revving the motor when cold. Simple as that. If it doesn't whine, it doesn't need chains.Frog wrote:What indication is there then that the timing chain job needs to be done on all these 5.6 motors. I agree the less the engine is opened up the better. Should I just wait and hope it doesn't fail or get it done?
