2011 M56 issue - Lock Switch
infinitim56
Car: 2011 Infiniti M45x
I have 2011 M56X, having a “interior lock switch issue”
I can lock and unlock the car using the “key fob” , but both passenger and driver side lock switches aren’t working (will not unlock nor lock the car from inside of the car)
Also, The windows are having issues they only go down sometimes and when I click quick to open and close them they do a very quick clicking for about 10-20 seconds and then stop.
Anyone know what could be wrong here or having the same issue?
Larz
Car: 2019 Q70-L RWD
I don't recall seeing any posts about this specific issue. Seems like a fuse issue, low battery, or ground wire issue. It's unlikely that driver AND passenger door switches would go bad at the same time.
infinitim56
I’ll look into that ! Thanks
Malbec 56 Beast
Car: 2013 Infiniti M66xS Totaled 4/11/20
What's next???
2010 Subaru Legacy
1983 Porsche 928 S Euro (Sold) 2/17/20
I would disconnect your battery for ten minutes and see if that changes anything.
If you are having a starting issue you will need to get a battery charger and charge the battery over night then do that direction first.
If you consistently drive about 6 miles one way repeatedly you will have battery issues.
Good luck
Andy
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
Larz wrote:
Mon Mar 30, 2020 4:20 pm
Would definitely look into possibly weak battery - numerous threads of the strange electrical gremlins that can occur when your battery is weak...
infinitim56
Jon Sarafolean took the whole door apart cleaned the harness plugs with electrical cleaner it all works good now ! Thanks guys !
Larz
Car: 2019 Q70-L RWD
Glad it was a simple fix! Stay safe and well
