There is another thread from a member who had the P0101 code, I don't think he updated us to the result.
For diagnosing both codes together I would start by looking over the vacuum hoses, checking for disconnected or damaged ones. Then you, or someone will have to start checking the sensors. I would start with the MAF.
- P006A - MAP to MAF correlation: Map sensor, MAF sensor, EVAP pressure sensor, Intake air temp sensor, Intake air leak, or a wiring issue with any of them.
P0101 - Bank 1 MAF
P010B - Bank 2 MAF
3.7L
Bank 1 - passenger side
Bank 2 - driver side
MAF - Mass Airflow Sensor
MAP -Manifold Absolute Presssure
