2011 Hatchback: Rear Brakes Squeal in Reverse Only
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
NicoInNC
Car: 2011 Nissan Versa
Despite brake service we are experiencing rear brake squeal while backing up in reverse. Any solutions would be welcomed.
PapaSmurf2k3
Site Admin
Welcome to NICO!
Typically brake squeal is attributed to either the shims on the back of the pads, or lack of (or improper) grease on the back of them. Grease (or other specialty substances) is often put on the back of the pad (between the pad and the caliper) to act as a damper and stop squeal.
Did you do the service yourself, or did you take it somewhere?
NicoInNC
Thank You.
We had it serviced and have since moved out of state from where it was serviced.
Return to “Versa Technical Discussions”
