2011 FX35 grinding noise when turning left
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
Brewcity1
Car: 2011 Infiniti FX35 AWD stock
Hello all,
My FX35 has developed a whirring or grinding noise when accelerating and gets worse turning left.
I took a look at the dust cover, and made sure it is not touching the rotor….so that is not it. It has clearance from what I can tell.
Can anyone give me some advice as to what to look for, or what it could be please?
Thanks so much!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Sounds like a wheel bearing. Probably the right if it's louder in left turns, but not necessarily, that depends on which side of the bearing roller is failing. You can't test them with a wheel-shake like old fashioned taper bearings, they can feel perfectly tight but still make God's own racket under load. You have to use a stethoscope, a good bearing will sound like something between dead silence and a passing breeze. The slightest ticking or clicking means it's bad.
Brewcity1
VStar650CL wrote:
Tue Aug 22, 2023 1:00 pm
Thank you SO much for this info. I was afraid that this was the culprit.
Is it alright to drive the car around 35-45 mph for the next day or two before I can get it in for repairs?
Should I be concerned of damaging something more?
VStar650CL
Technical Expert
I've actually seen Nissans go 10K miles and more on a bad bearing, they're roller types and it usually takes a loooooooong time for them wear down to the point of being dangerous. I wouldn't worry too much. To be safe, just don't take any long trips with it that might make the bearing run hot.
Brewcity1
VStar650CL wrote:
Tue Aug 22, 2023 1:48 pm
Awesome....thanks again for the help. I really appreciate it.
VStar650CL
Technical Expert
:dblthumb:
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
