Sounds good, will open up panels and lube everything. Thanks againVStar650CL wrote: ↑Thu Jan 09, 2025 11:50 amSome WD or PB in the lock assembly will usually help, but you need to pop the door panel and hit the whole assembly, including the cables. Don't use silicone, it won't chase water as effectively as penetrating oil and it can also compromise the insulation of the actuator motor windings.
