ppan76 wrote:I was able to find the 2010 Service manual. Anybody knows where to get the 2011 version?
I am a new 2011 EX35 Owner. So far I love the car. My last car was a Nissan Murano and I am looking on doing the Video Bypass Mod. I have a 2011 EX35 With the premium package (Navigation). I did the mod for my murano and loved it. Want to do the same for the 2011 EX35
Thanks.
I don't believe that you even need the relay to make it work; you just need to have the VSS and parking brake signals wired to ground via a DPDT switch. I don't even think you need the switch itself, but it's highly recommended that you do use it (for the GPS signal lag and such). The thread for this mod in the Armada/QX56 forum has this covered in pretty good detail:TonyN wrote:sorry to bump a old thread but i found this
2008-2009-infiniti-ex35-emergency-brake ... 70900.html
however it is now blank. does anyone have the saved instruction, i would like to the do the relay to keep the stock wiring/function. On the other hand can anyone confirm that if I just ground the VSS and Parking sensor that it will have no negative effects? like GSP signal being slow for navigation.
I believe the 'right' wires depends on which audio system you have in your EX. Do you have the Base Audio, Bose Audio w/o Nav, or Bose Audio w/ Nav? I think the wires may be in different spots on the connector for each of the different audio systems. It also might vary by model year, so what applied for the 2008 may not necessarily be right for your 2010.TonyN wrote:Thank you for the response. I am not worried about the dash removal or anything like that, I am just concerned about which wire color since it seems different on each. I guess I have to download and go over the FSM, I was hoping to find it since others have done it before and seem to have posted pictures of the exact wire, however now it is missing. Basically I ground the parking wire coming out of the plug and put a toggle switch for the VSS.
So if anyone remebers the exact color for the parking and VSS I would appreciate it.
Since the FSM for the 2011 have been posted. I was able to get the information. The wires are the same as the 2010 EX35 with NavTonyN wrote:Thank you for the response. I am not worried about the dash removal or anything like that, I am just concerned about which wire color since it seems different on each. I guess I have to download and go over the FSM, I was hoping to find it since others have done it before and seem to have posted pictures of the exact wire, however now it is missing. Basically I ground the parking wire coming out of the plug and put a toggle switch for the VSS.
I don't think you're mistaken. If you so choose, I recall that you can use a SPDT switch for switching just the VSS signal connection back and forth to ground, and for the parking brake signal you would directly wire it to ground. The guys in the Armada/QX56 thread recommended the DPDT switch for warranty or diagnostic purposes, but I never found out how the signal inputs would affect any diagnostic procedures or outputs through the AV system screen.TonyN wrote:Perfect, thank you for that. However from what I have seen you dont need that type of relay/switch. Just a normal switch to brake the connection for vss or connect it for continuity, and for the parking you should just ground the wire coming from the harness. Am I mistaken on this?
I don't remember seeing that thread, but if you find out which of those wires are the right ones (or if you find that thread), let us know!TonyN wrote: Also I can't find that thread now but someone found the VSS and Parking wire/harness hear the driver side footwell bt the door. That seems like a muvh easier option and would be a cleaner install. Does anyone recall that thread?
You are not mistaken. I decided to use a DPDT switch to completely switch the connections back to OEM/Normal mode.TonyN wrote:Perfect, thank you for that. However from what I have seen you dont need that type of relay/switch. Just a normal switch to brake the connection for vss or connect it for continuity, and for the parking you should just ground the wire coming from the harness. Am I mistaken on this?
When you go into diagnostic mode. There is a screen that shows:NJGuy wrote: The guys in the Armada/QX56 thread recommended the DPDT switch for warranty or diagnostic purposes, but I never found out how the signal inputs would affect any diagnostic procedures or outputs through the AV system screen.
found it but it seems it will only work for the All around Camera, you still need to get behind the dash for the DVD/NAV imput bypassNJGuy wrote:TonyN wrote:
It looks like the around view camera system has its own separate source for VSS signal. The guy who posted the thread about this mod on the infinitscene site had stated that.TonyN wrote:BTW when you ground the parking wire and make a switch for your VSS, the All around camera will not work at speed. Weird because I thought this mod would bypass the all around camera speed lock out also, guess not.
I think the part number you're looking for is 34922-EG00A.TonyN wrote:Also, anyone know the part number the retaining clip of the shift knob, i still cant find it.
