VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Tue Jul 20, 2021 6:25 pm
P0725 is an indirect code in the transmission, it means the ECM stopped transmitting engine RPM. Your chassis code was probably C1130, which is the same thing from the ABS. Neither one means anything, they're both "consequential" to the ECM tossing a code which caused it to stop transmitting. They both may be leftovers from your original MAF problem. There are really just three things that can cause a no-run situation like that without throwing codes. One is a horrendous vacuum leak like a broken intake boot, but you'd probably be hearing that. Another is fuel starvation. You can check that easily with a can of Brakleen or Gumout, spray some down the intake past the air filter. If it runs normally for 5 seconds and then quits again, your problem is fuel. The last possibility is the MAF. Nissans have no MAP sensor for the ECM to double-check the MAF, so the ECM basically has to trust it. If it's lying, you usually get a start-no-run just like you're seeing. Check to make sure it hasn't swallowed a butterfly wing or some other debris, and since it was just changed, check that a wire didn't get twisted and broken. If you have a streaming scanner, check the airflow and see if it looks normal. Most engines draw a bit more than a gallon of air per liter of displacement when cranking, so after you're sure it's clean and there's no broken boot, if it's below 1 gps or above about 3.5 gps then you have a bad-new MAF.
