robj80 »
https://forums.nicoclub.com/robj80-u980.html
Mon Oct 08, 2018 6:45 am
Just following this up. I never did exactly pinpoint what was the issue. The old hub was really rusty and while I didn't see any play it was a bit gummy when spinning it by hand. The caliper definitely had a torn boot on the piston and was slightly firm to push in. I didn't think it pushed in too hard though. Because of this I replaced both. The caliper, bleeding, and hub took 1.5 hours total to complete.
The new caliper went on no issues. I gravity bled it first then with help did the pump method just to be sure. Braking is as good as ever.
The hub surprisingly was a cinch despite all the rust. Even the sensor came right out. I bought another one just in case but I am returning it. The four bolts unbolted easily with an electric impact. I was actually able to take one off with a breaker bar but figured if the impact fits I might as well use it. Once the bolts were out the hub was a bit stuck. I have a 5lb maul (wood splitting ax with sledge on back). A few whacks with that and it came right off. Everything went back together easily.
Went to test drive it and the vehicle wouldn't start. I knew the battery was going. I finally got it to start so drove straight to nissan for a new battery. I found nissan sells the cheapest batteries around here. I had them install it while I waited in the car. Because I had a coupon for the battery with installation it was actually cheaper to have them install it instead of me doing it.
