2011 37 convertible/ roof leaks
Dedicated to the G37 Convertible. This forum is for convertible-only content that is NOT covered in the other G-Series forums.
iatoner59
Hi
I'm new to this forum. I just purchased a 2011 g37 convt on June 19th. The first time it rained I had water leaking out of the tweeters and a couple of smaller leaks on the center windshield and the drivers side window.. I'm concerned that this will not be an easy fix.. Any advice on how I should approach the dealer and when does the "Lemon Law" come into play. Thanks in advance for any advice given.
iatoner59
audtatious
Lemon law won't come into effect unless they try to repair the same issue a number of times and it fails. Take the car to the dealer and simply tell them what happened. They should easily be able to replicate the problem and they should resolve it with no issues.
joe603
Car: 2014 Durango R/T
I agree with Matt. Dealer should be able to take care of you.
bigscott
I would get that car to the dealer asap. don't let it go to far
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
I had this issue as well. Its an easy fix that takes them about 5 mins to do. Its adjusting some of the rubber around the window. Also there is a tract that leads water near there and if it gets clogged it can do this. My dealership fixed it, but mind you this is a convertible, the way the windows work, if it rains really heavy and you have tons of wind, you can get some water leaks. This is true for any convertible I've known. The BMW was the worse I drove.
iatoner59
Thanks for your input.
Fezzik
No problem. Welcome to NICO
Return to “G37 Convertible Forum”
