Nissan090867 »
https://forums.nicoclub.com/nissan090867-u311301.html
Wed Oct 25, 2023 6:17 pm
Anyone have a 2011-2013 QX56 with over 200,000 miles that did not have to have a timing chain replaced? The reason I ask is I just purchased a used 2011 QX56 that was not affected by the timing chain recall that only has 100,000 mi on it. It is in mint condition that was garage kept. I love the vehicle but did not know there were timing chain recall issues with this model. I'm debating on selling it, or keeping it based on responses to this question. Infiniti consumer affairs and the infiniti dealership service managers are essentially useless on explanations of why my vehicle was not affected. They do not even know the root cause of whether it was a timing chain defect or if it was caused by a lack of lubrication. The service manager at infinity told me today that it was because the timing chains were not beefy enough and that the recall replaced them with more heavy duty timing chains. If that were the case, all of these models would have been recalled. When I pressed him further, he confessed that he really did not know for sure. I believe based on my reading of the forums that it was due to improper fit of some of the oils jets resulting in oil bypassing the jets that were supposed to spray lubrication onto the timing chains resulting in the chains stretching over time. This particular vehicle that I have may not have had its engine manufactured in the range where the defect was generated. But not sure since no one from Infiniti can give me a sensible, verifiable answer. That is why I'm posting this question to the users. I have seen Reddit posts where some 2011 through 2013 QX56's that were not recalled timing chains failed in the same manner as the affected ones. That is why I'm searching to see if any unaffected ones made it to the 200,000, mile range without having to have a timing chain replaced. Thanks in advance for any replies.
