2010 Versa Horn Wire at steering column ?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
jenom
Car: 2010 Nissan Versa HB CVT
2010 Versa clock spring ribbon cable is completely broken, so the horn is no longer works.
I am trying to identify the horn wire at the back steering column connector, so I can use an external momentary push button switch.
Anybody knows which connector has the horn wire ? what color ?
maybe a wiring diagram showing connectors with pin numbers, etc...
Thank You !
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Return to “Versa Technical Discussions”
