Nissanjunk »
https://forums.nicoclub.com/nissanjunk-u164206.html
Mon Jul 12, 2010 8:41 pm
"A couple of problems"? The Titan is plagued - axels seizing, bearings failing, differentials fragmenting, engine mounts shearing, transmission mounts tearing, 4x4's failing to go into 4-wheel fresh off the lot resulting in broken front axels, transfer cases splitting, exhaust manifold cracking, etc.....Well, let's stay on the Versa topic here. Every manufacturer has their problem children, I understand that. I'm giving the dealer the chance to make it right and I'll go from there. I will be interested in finding a better spring for it eventually. The ride is very soft/spongy. I know alot of it has to do with the tires that are on it. I just want it operating correctly to start with, then build from there.
