NicoClub does have the FSM - and I've consulted it. It says nothing about this "hot" mark - only says to drive it until fluid is between 50C and 80C (or about 10mins at 68F outside temp), and then it says that it should be between the two marks on the cross-hatched area. Following this (and guessing at the temp, because we don't have a Nissan scan tool) we are a bit above the F line, but not too much.macgiver wrote: ↑Wed Nov 15, 2017 5:00 pmI saw FSM and for mine the crosshatched area (and for most automatics) is the sweet spot ,better @ top usually and warmed NOT HOT , fluid expands greater in these small transmissions - I "believe" this way higher "Hot " marking is just that - how if you overheat them ,and they can go into a limp mode for that , overheated motor&trans cause it to rise to that mark !? ! But it's critical to "Know for sure", does nicoclub have your FSM ?
