2010 Rogue serperntine belt
ithinksgreen
Hi Guys,
I was at the dealership for oil change at 34k for my 2010 Rogue, I am a city driver with no long trips. the dealer recommended to change the serpentine belt. can you guys share your experience at what mileage you got it changed or at what mileage it should be changed.
Thanks you.
Leo2005
Please use search button on the top in the future. Here's all the info when, how etc.:
post6577129.html
ithinksgreen
I did perform the search, all the results i see is about how to replace it. my question is how long does serpentine belt will lasts on rogue's or what is the recommended mileage at which it should be changed
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
ithinksgreen wrote:I did perform the search, all the results i see is about how to replace it. my question is how long does serpentine belt will lasts on rogue's or what is the recommended mileage at which it should be changed
Looks like you missed this post as well: serpentine-belt-and-cvt-change-t556523.html#p6318247
kerrton wrote:Regarding the serpentine belt, this is a very important belt and in my experience its tough to accurately judge wear visually. The ribs will wear down evenly and can look good but when compared with a new belt you will see that they have significant wear. Also the rubber gets old and cracks as your service guys report, but you're generally good for 5 to 7 years with typical driving. I always try to error on the side of caution especially if you're long highway road trips (i.e. you don't want to get stranded) and I change mine generally about every 5 years.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
rubber is rubber; there is no age, mileage, nor time limit on rubber parts.
everyone's can fail at a different times. rubber degrades at different rates. someone who does 150,000miles on the highway with cool incoming air - is going to have the best last longer than the guy sitting in city traffic and not having cool air incoming onto the belt(rubber parts).
ithinksgreen
Thank you guys
Ezh10111
Car: 2010 Nissan Rogue SL
I have a 2010 Nissan Rogue and keep having trouble with the serpentine belt. The belt seems to be on too tight. I've replaced the idler pulley, alternator pulley, ac compressor and still can't find the problem. I'm using the Dayco 5060710, but it keeps coming off. I have to turn the tensioner all the way, and I'm still having trouble sliding the belt on. Does anyone have any clue what's going? Thanks
Rogue One
2022 Honda Pilot SE
We have an incredible SEARCH feature on this forum. Merged with existing thread.
--------> READ BEFORE CREATING NEW THREAD! <--------
IIRC the system is temperamental and the OEM part works without any issues. Try using an OEM belt rather than a 3rd party knock-off.
CHATROOM: Engine Fan Serpentine Belt
Serpentine Belt and CVT Fluid change?
Noise after Serpentine Belt
2010 Nissan Rogue Question!!
Part Description: Belt-Fan & Alternator Part No.: 11720-JG30A Replaced by: 11720-JG30B
http://www.rockauto.com/en/parts/nissan ... ,belt,8900 $41.79
https://www.courtesyparts.com/oem-parts ... 11720jg30b $38.99
https://www.nissanpartsdeal.com/parts/n ... jg30b.html $37.74
https://www.amazon.com/Nissan-11720-JG3 ... B00BFE3FZM $32.99
Ezh10111
I installed the oem belt but it still came off. Anyone have any clue on what's wrong? Thanks
darylzero
Ezh10111 wrote:
Thu Sep 21, 2017 6:46 pm
My guess would be your Drive belt auto-tensioner. When you replaced it did you check if it was the exact same as the OEM?
There is a grove at the automatic tensioner pulley that must be aligned properly.
Return to “Rogue Forum”
