VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Thu Aug 01, 2024 4:08 pm
Parts are expensive and electrons are cheap. Before throwing parts at it, scan the MAF readings and see if they're stable and reasonable. The list of things which can cause poor performance without throwing codes is very short. On a gen1/gen2 Rogue, it's basically MAF, fuel pressure, cam/crank sensors, plugged exhaust, and a few other things which are far less likely. Your symptoms don't jive well with cam/crank or exhaust, so that leaves MAF and fuel.
