2010 Rogue cranks but won't start
hmarie95
Car: 2010 Nissan Rogue
I went to start up my car this morning (it was 18°F) and it wouldn't start. Sometimes when it's cold it does give me this issue, but after one or two tries it turns right up and I don't have to deal with it for the rest of the day. It's definitely been even colder than it was this morning and started up just fine.
There is oil in the car...
There is fuel in the car...
The battery is not dead...
For some reason, fuel just isn't moving. I tried for a while, even pressing the throttle to give it a little kick but... Nada.
:poke: I don't know much about cars, but I do know that I don't want to spend over $200 to have someone look at it and tell me that the filter is clogged.
Anyone have a similar issue and been able to avoid spending too much to fix it? Maybe have any idea how to just kick it and get it started again? :gotme
Rogue Jarhead
Car: 2011 Nissan Rogue Krom
I think you’ll have to explain in detail what it did or did not do.
Engine cranks over but didn’t start?
Lights on dash light up when you turn the key but engine doesn’t crank?
Cranks slowly? Cranks Fast? Does it sound like it always does when you try and start it?
Do you have a multimeter and do you know the basics of using it if you do?
How many miles? What year? 2010? How old is the battery?
Does it only do this when it’s very cold? Or when warm also?
prj
Car: 2018 Nissan Rogue. 2004 Nissan Titan
Bad fuel pump. Bad Fuel injectors.
Bring it in and get it fixed.
Return to “Rogue Forum”
