jsavage81 »
https://forums.nicoclub.com/jsavage81-u276644.html
Thu Aug 17, 2017 10:07 am
I LOVE my Nissan Rogue, however about 2 months ago I had trouble starting my Rogue intermittently. The problem started when I felt a kick in the engine which felt like a very brief loss of power. I then turned the car off and when I tried to start it again, the Service Engine, VDC Off and Slip lights were all on. My car started about 10-15 minutes later without an issue, and only the Service Engine Soon light remained on. We changed the battery since the Rogue is 7 years old and the problem went away for 2 weeks. Then I couldn't start it again and we had a mechanic check the codes and the Camshaft position sensor code was reading, so that was replaced. Another week goes by and same problem, can't start it and when it finally does the Check Engine is on. The mechanic tried changing the Crankshaft position sensor to see if that would resolve the issue. It seemed to for another week. I finally took it to a dealer who said their best guess is that a short is causing the intermittent start issue (they couldn't replicate, it was starting right up each time). To repair, they think replacing the wiring harness MIGHT fix the problem. They would not guarantee that it would fix it. Has anyone ever run into this? The dealer told me it was a one in a million.. (WHY ME!?!) The repair would cost around $3,500. Any insight is greatly appreciated. Unfortunately I'm planning to test drive the CRV and RAV4's this weekend.
