2010 Nissan Rogue.. Buzzing noise when accelerating
Pierrextc
Car: 2010 Nissan Rogue
I've been an owner of a Nissan Rogue for the past 10 yrs (150'000 miles) and been lucky enough to not experience bad luck on my CVT transmission but I feel like my lucks about to run out. Recently been experiencing a buzzing noise when I accelerate. Timing is fine and car doesn't rattle or lose power just that weird buzzing and its only between 15 and 70 MPH. I've heard many thing about it. Bearings, loose screws, not changing transmission fluid (which I did awhile back). I've always been the only one to work on my Rogue and its been going great till now and because I feel that its an internal issue I might have to bring her in but before throwing down thousands of dollars I'd like to see if anyone has experience the same and what did you end up doing. Thanks hope to hear from someone fast.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Yes they have. Search the forum for CVT noise.
bill875
Car: 2008 Nissan Rogue SL AWD
Indigo Blue
Premium Package / Fully Loaded
After you've driven your car and heated everything up, put the car in park and rev the engine and see if you hear the buzzing. If you do, It could be an exhaust heat shield that is loose and causing the buzz sound. Take it to a muffler shop to have them weld the shield(s) back in place. I've had to do that twice now on my 2008 SL AWD.
^ This. Had the same problem on my Cube.
Good luck, and welcome aboard!
Return to “Rogue Forum”
