Could anyone share, or point me to, the Electrical schematic for the rear door (Door 5) release motor? (without Power Lift)
I found one, as an image, showing a relay coil powered by the BCM, with Normally Open contacts in the supply circuit to the release motor. But it does not identify which vehicle or the year, or where the relay is located.
Thanks in advance if you can help.
