2010 Murano code p0725
Forum for the unique Murano, and official home of Nissan Murano Club!
legend67
Car: 2010 Nissan Murano
2010 Murano with 184,000 miles,
When it snows and the roads are slushy. The car jerks at time under wet conditions only. (P0725) I have done a fluid change and cleaned the filter. I actually installed Napa 1-5647 filter kit and found the pickup tube was too long and when I tightened the pan it crushed the filter, so the pump was being starved for fluid. Reinstalled original filter and back to normal.
The transmission was replaced under warranty by the previous owner. I purchased it with 176 thousand.
Any thoughts
thanks
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's a 2011 bulletin regarding that code, NTB11-043. It's most probably being caused by a dying crankshaft sensor (CKP) that's occasionally skipping teeth. Make sure you check sensor ground for the CKP while you're down there, we've seen it be problematic on gen1 Muranos. Here's a copy of the diag flow from the bulletin:
https://drive.google.com/file/d/1QeTmxD ... sp=sharing
This is a case of the TCM blaming the wrong component, similar to how it blames the range switch with P0715 for what usually proves to be water in a taillamp.
legend67
Thanks I will check the wiring and sensor
VStar650CL
Technical Expert
You're most welcome. Come to think of it, since you're only getting the issue in wet/slushy conditions, I think the wiring or connector would be a more likely culprit than the sensor itself.
legend67
Thanks that it what my thoughts also. I purchased some dielectric grease.
legend67
I removed CKP finding the wiring to be fine and sensor clean. I did find the the sensor seemed to have a open space between transmission grommet and the sensor.. I did install a o ring on the sensor to close the space. Hopefully this cures the problem. I will keep everyone up to date when I know if worked or not.
Return to “Murano Forum”
