2010 maxima p/l and passenger windows dead
Robbyrob215
Car: 2010 maxima sv
Hi my first post here but I’ve been buying and selling a lot of these gen maximas lately and this problem has me a little stuck. The power locks work with key but not on ether door, the driver window works but no other go up or down from any switch. I did use a volt meter and have power to both front doors. But no power to yellow wires which I assume would be constant 12 volts in there. Just seeing if anyone had a similar problem here appreciate the help guys
Ps
Had a horrible alarm setup that took me most the day to pull out and return to stock
I’ll be checking further to the wiring tomorrow and try to also find a new main window switch
macgiver
mac , just don't put 12v on yellow SRS Airbag wiring - :rotflmao
audtatious
Check the power coming out of the switches on the driver door. I've seen the main driver panel go out and cause similar issue.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
Robbyrob215 wrote:
Wed May 16, 2018 8:19 pm
you can get new (and used) master switches on eBay
https://www.ebay.com/sch/i.html?_from=R ... _PrefLoc=1
