EdBwoy wrote:Sorry for having to deal with this for such a long time. Let's try to solve this before the drivetrain warranty runs out (or has it already?)
1. Have they put the stethoscope on the exhaust manifolds to isolate the precats?
2. It doesn't seem like your engine is shaking from the video, but is it shaking IRL? Also, does the sound change when you shift from P-R-N-D? Does it shake the car? If so, check the engine mounts. Those usually cause that deep knocking sound
3. How's your oil level? Have you had bad consumption problems since you saw the big puff?
Warranty has not run out, I did purchase the Elite till 75k, 2017.
1. I was told at one of the multiple times I took it in, that they did, and that they didn't hear it, and cant decipher. It is very difficult to believe it since I can hear it audibly without any help standing outside the car, they have acknowledge the noise but deemed it normal.
2. Disclaimer, the video posted above is not mine, though it sounds very similar. I will take one for my vehicle though, and post it. The sound is not there on P, and rarely on N. It is there on D and R, consistently. When stopped on either D or R, I was idling at 400 - 500, really low. I addressed it multiple times, and they finally adjusted it to 750, and the noise disappeared for a bit. But it is back. I will inquire of the mounts in the next time I bring it in.
3. Oil level consumption is almost 1q per 1k. I usually add a q every half oil change interval, so after that big puff, it pretty much has stayed the same.
I was told that it was normal for the V8s, then after a while, somewhat relented and say its not that normal, but then again, its not that big a deal. I took it to another dealer, they acknowledged the noise, but was told that it needs to be louder before Infiniti can approve any fixes. Basically, they dont think its broken at this point.
It almost seems like either an easy fix, that can really be a big problem in the future. The worst part about it is the lack of clarity in the situation. Is it ok, or does it need to be fixed? Info in the interwebs is quite limited too. Getting a bit frustrating.
