fat3oy »
https://forums.nicoclub.com/fat3oy-u190004.html
Thu Oct 10, 2013 12:16 pm
Check grounds... and see if it gets worse when the door opens and the interior lights come on... if so... it is a grounding issue, and you need to install another chassis ground wire, or re-ground the cameras wires...
To further confirm that it is a ground issues, the camera picture should look like an old tv, with lines going through it... or like snow/bad resolution...
