2010 M35S. Sporadic chime at low speed with no warning light of problem. Chime is loud with no pattern.
rikcro
Car: 2010 Infiniti M35 S
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If it's either a key-left or door-ajar chime, check your door switches. Worn-out rubbers can cause the door signals to false as the chassis flexes over bumps or around bends. Depending on whether the BCM or cluster controls the chime in your particular ride, if it happens fast enough, the car may not respond with a visual warning.
2007infinitim45s
Car: 2007 Infiniti M45 S
Could be the lane departure warning system?
