2010 G37xS Sedan ride Question
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
We noticed on our new 2010 G37xS Sedan that the steering wheel vibrates/shakes from time to time. I had it in for the dealer to look at, and they said everything was fine. While that was in for service I had a loaner, same car EXCEPT it did not have the Sport Pkg. The loaner car steering wheel did not shake at all. The service dept said that the Sport has a bit of a harsher ride, and this was the cause. What is strange is sometimes the steering wheel hardly shakes, and other times it has a much more prominent shake.
ANY IDEAS FOLKS? Or is this the way it is supposed to be? :confused:
exit9
Car: 2010 G37xS Prem/Nav
Mine does not vibrate. You may have an out-of-balance wheel. Does it vibrate at a specific speed? If you release the steering wheel does it pull or drift?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
If you can feel vibrations in the steering wheel, then the issue is in front suspension or front tires. Have them re-balance the tires regardless if they can feel the vibration or not.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Did they check the balance?
If it is within the 12/12 adjustments warranty they should cover it no charge.
If it is under braking then the rotors might have some parallelism from sitting or uneven cooling.
Timmbo
They say there is nothing wrong, that it is normal for the Sport model. Happens usually around 65-75mph, some highways are not as bad and it doesn't shake at all, other times it is pretty bad. It does not happen during breaking.
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
A balance check wouldn't hurt that is right in the speed range where we usually see a little imbalance causing some issues at highway speeds.
Timmbo
They did check the balance, they said that was find, but they did not check the alignment, they said if it was the alignment it would shake all the time at highway speeds.
esanger
I am no expert, but I would say it is a balance issue. I have found that balance in one tire can cause the steering wheel to vibrate and make the car feel like there is a major issue. Be careful who you have check your balance too. Places like Walmart seem to care less about getting the balance precise which provides the smoothest ride. Last time I took it to a Firestone place and paid more than Wal-mart but the ride was perfect when the car was done..
Timmbo
The Infiniti dealer checked the balance.
joe603
Car: 2014 Durango R/T
Have the dealership do a rid-along with you....
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
