2010 g37 stall at 2500 rpm
nefg37
Car: 2010 infiniti G37 coupe
my 2010 g37 stall at 2500 rpm, i wonder if anyone else experience the same thing i keep getting code p0011, i had changed most of things relating that code, any help will be appreciated
larsG35
Car: '04 G35 6MT sedan
Can you be more specific of what exactly you replaced or checked related to this issue?
If I understand correctly, this is a timing issue code? I think this is often oil pressure related. That would make sense with the stall I guess.
Lars
nefg37
yes it is timing code, i have change both cam sensors,crank sensor and one valve timing solenoid that was bad and of course change oil, but the problem still there,a friend told me i need it to take it to infiniti dealer so the can program computer to relearn codes i don't know much about this car any help will be appreciated before i keep spending $$
larsG35
It seems to be a pretty difficult part to check, but it might be related to the oil galley cover/gasket.
checking this post on 350z-uk forums might help.
http://www.350z-uk.com/topic/99607-zed- ... y-gaskets/
Good luck
nefg37
great info thanks for all that information, ill do the oil pressure test to be sure before i put $$ in to it, i just wish there was a way to know what bin # or year have this problem, i always heard it was only on the g35 not g37
larsG35
Yes, I'm not sure what year they started to reinforce the cover. I think it might just be that all of the vq35 engines are old enough to have this issue and the vq37 engines are just starting to have them periodically fail.
nefg37
thanks for all your info, i have been reading more about this issue, my mechannic is positive that my car don't have that issue he thinks is something else cause he said my car don't have those symptoms only that stall after 2500 rms but im going to do a oil pressure test to see what step we take next
larsG35
I hope you find a fast reasonably priced fix.
Once it's fixed, if you have time, consider posting the answer to this thread so it helps others that might have this issue in the future.
nefg37
for sure ill do that....
nefg37
I did the oil pressure test and it passed fine and other checks and all went ok,we use the OVD II for live data oxygen sensor and VVL both connected to fuse 46 not getting any voltage but fuses are good. that's where we stand now.im hopping to hear some one here went thru that....
nefg37
im taking car to infiniti dealer on friday, i will post the finding just incase anyone goes thru the same issues
nefg37
Ok, i took car yesterday to dealer and it was what i always assume engine sprocket where bad $3,500 job after talking long hours with them the extended warranty pay $1,000 and i end up paying $1,900 after a discount the dealer gave me, they said 3 days before i get car back, i only wish i had done this before and t not waste almost $1,000 changing sensor,oil,crank shaft sensor.... who ever goes thru this best deal go and pay the dealer $165 to check codes
nefg37
.... and for those who think that the paper gasket seal problem its only on the G35 it happened to my 2010 G37 and no recall for this yet
larsG35
Yeah, I kind of had a hunch that the problem was never really fixed by Nissan and all of the VQ37 were just still too new to have the issue show up.
It's certainly a huge pain in the butt, although I suppose it could be worse. I'm glad you at least found out what the problem was.
Have a good day,
Lars
nefg37
update; after infiniti mechannic open engine he did not say it was the seal he said it was the engine had oil slush and that make the sprockets lock and that was the reason of my problem...
nefg37
got the car back today running sweet,code P0011 the dealer change sprocket-camshaft intake both of them and guide-chain, tension side and pully-tensioner parts where $1,500 and lavor was $1400 i had an ext-warranty cover $1,000 and i had to pay the rest, hope it help if someone go thru the same thing,my car went on limb didn't pass 2500 rpm and it gave me code P0011 only i did lots of thing that code ask to do but nothing fix it only when i took to dealer , good luck hopefully no one have to expierience this too expensive
