g25dragon »
https://forums.nicoclub.com/g25dragon-u170016.html
Wed Oct 13, 2010 8:17 pm
Okay, so here's my opinions on the list of "premium". Premium is more for your peace of mind and probably won't make your car last any longer than it would if you just followed the other schedules. And your warranty does not require you to follow the premium schedule. If you have the money and aren't sure, go ahead, it will make you sleep better at night. Otherwise, you can selectively choose what needs to be done.
- Lubricate all locks/hinges
can't imagine how much Infiniti would charge for that, an hour labor?
- Replace automatic transmission fluid
as hard as this AT works, 30k-45k seems reasonable.
- Replace differential oil
30k seems a little extreme, maybe 45k-60k?
- Replace engine drive belts
Most likely not necessary, a good honest mechanic can usually tell you if the belts still look like they're in good shape or need to be replaced.
- Replace radiator cap
easy enough, but probably not necessary.
- Replace wiper blades
you know when they need to be replaced.
