2010 FX50S - winter rims
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
NSRUSS
Car: 2010 FX 50 S
I am looking to source 21 inch steel wheels to use for winter tires
Does any one know where I can find these.
Thanks
EdBwoy
Those will be heavy! Coming from the forged 21"s, you'll probably feel the weight at take off.
I don't know at what point it becomes better to just go with aluminum wheels; manufacturers do it not just for looks, but weight/ fuel economy as well.
I'd consider 18 or 19 inch wheels (aluminum or steel) so that you can have higher profile tires as well. I know it was difficult enough to find 19 inch winter tires, but there are a lot of SUVs and other crossovers using meaty 18 inchers. If you get the wheels, the correct tires might be quite expensive.
From google, "Detroit Steel Wheels" comes up as a custom builder, maybe ebay would yield something in the correct specs.
Sorry I can't answer your original query with certainty of experience, but I hope this helps in one way or another.
NSRUSS
Car: 2010 FX 50 S
Appreciate the feed back and input, Aluminum is a great idea for sure.
They have to be 21 inch because I already have 21 inch snow tires.
I will check out your Detroit idea
EdBwoy
Ahh, I see now. I had assumed you were looking for both wheels and tires.
Please keep us updated with what you find.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
