2010 fx35 TOWING
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
gsenties
Car: Infiniti J30
Does anybody know the reason why the 2009,2010,and 2011 FX35 are not rated to tow even a small trailer? Older and newer models can tow. I would like to tow a small boat (under 2000 pounds) with my 2010 FX 35.
Thanks
EdBwoy
I have no idea why, but sure enough the owner's manual omits the RWD car from its ratings. Apart from a little extra weight from the AWD components, I don't see what would be different.
What's curious is that in previous years, all (RWD v6, AWD v6 and the v8) were rated for 3,500lb.
In the 2010, only the AWDs (v6 and v8) are rated, a measly 2,000 lb at that.
I live more on the edge, testing the boundaries of the safety factor as long as I use the load spec chart [owners manual, section 9-22], but if you have the 2WD vehicle I wouldn't encourage you to.
Hopefully someone with more direct experience comes by and sheds some light,
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
