My 2010 EX35 drivers side window switch occasionally does not work. It will go down, but not up unless I play with it a few times... passenger window goes down but not up, but works fine from the passenger side switch. I took out the old one and cleaned it and the circuit board, but still not much better so I'm buying a new one.
The part # is 25401 1BA3E. I'm finding lots available starting with #25401, but the next numbers are JAO1A, 1B, or ZN5OA, OB, OC. The fittment is for Altimas and others, but not the EX35. The pictures look exactly the same as my original 1BA3E and range from $30 to $90 and are for auto-up widows both sides, which mine is. Do you think these will work for me?
Ironically, Switch Doctor offers one for $97 that says its for a 2010 EX35, but the picture shows two mounting screws at the bottom, which mine definitely doesn't have or need for installation (it pops-in completely).
