wysguymd wrote:Still haven't resolved the problem after countless trips to the dealer. They finally had a tech from Infiniti come out and install a data recorder. Haven't taken it back yet since recorder was installed, but issue has not resolved.
Does it happen during startup (engine cold) or startup after driving the car ? (Engine warm)
Does it happen when the engine is already idling ?
I had issue with my 2008 EX35 stalling during the startup when engine has driven for a while. ( warm startup like going leaving the grocery etc.)
I did replaced the battery and it was still happening until I cleaned the throttle bodies and reset the idle computer sensor relearn. If this is the issue, the build up of gunk in between the throttle plates cause the throttle opening sensor to open a bit and readjust it's base settings (throwing off the normal idling of the car). When I cleaning the throttle bodies , do not flip open the throttle bodies just clean the side or edge of the throttle plats where the gunk builds up. Moving the plates will throw off the sensor permanently and needs to replace the whole throttle bodies.
http://www.altimaforums.net/idle-relear ... 9&p=409249
