2010 Altima no acceleration
General discussion area for the L32-chassis Altima
rpatel1053
Car: 2010 Altima 2.5 S
I own a 2010 Altima 2.5s with 49k miles. I have noticed a problem. It has happened twice in a year. First time it happened was last summer. I was leaving from work when I lost complete acceleration. I put the car in park and back in drive and every thing was fine.Next day I hooked up consult III but there were no codes. I could not duplicate the problem. It happened second time three days ago at a local shopping center. Please advice me if any one has encountered the same problem and has an idea of what the fix is. I called Nissan Consumer Line. There are no TSB's, Service Campaigns.
sstroudwku
Car: 2013 F150 EcoBoost 4x4 - BlueJean Blue
2014 Pathfinder
Check the pin connections on the top of the Pedal Assy, I've had some come in where customers have managed to kick them loose. I've also had some come in with adjustable pedals where they have come loose. Not the case in your part. For shiggles update the ecm next time you have access to cIII+
rpatel1053
I have been researching into the problem. I went into NHTSA and they have a TSB. NTB11-002A. For the issue.
Throckmorton
Car: 2007 Altima
rpatel1053 wrote:I have been researching into the problem. I went into NHTSA and they have a TSB. NTB11-002A. For the issue.
I don't think this TSB is applicable to Altimas.
NTB11-002
2010 NISSAN MAXIMA, MURANO; MIL IS ON AND / OR SLOWER-THAN-NORMAL ACCELERATION
The vehicle has slower-than-normal acceleration from a stop at times
and / or
The customer describes the vehicle has slower-than-normal acceleration from a stop at times
and / or
The MIL is ON with DTC P1778 (STEP MOTOR) stored in CONSULT III (Engine and / or Transmission).
AlexN09
Car: 2011 Nissan Altima Coupe S 2.5
Many people have described this symptom. Look up "limp mode" with regards to the altima with cvt. read through a few because some people having differing experiences.
rpatel1053
Thanks I will look into that.
Nizzed
Car: 2007 Altima
The 2007-09 Altimas 2.5s auto cvt have the same issue and at 110,000 miles I'm dealing with the p1778 step motor code. The code says electrical is fine but there is a mechanical failure in the speed transitioning. I've read that solenoids is the problem (but not directly from a DIYer who fixed it successfully) or that its one of the pressure valves (there are three or four) This is the Jatco CVT JF010A
Return to “4th Generation Altima Sedan (2007-2012)”
