2010 Altima coupe OEM radio
All things Altima Coupe.
elchingogon
Car: 2010 Altima coupe
The radio on my 2010 Altima coupe's digital display is not working. everything else works but I cant see the LCD. I wanted to replace it with another from a 2010 sedan or with a Bose OEM radio from another car but I dont know if they are compatible. can I just connect it and they will work like the Original on the car? Ive found a few but they have different part numbers but look exactly the same. Please help,
Thank You
shortys408
Car: '11 M37S
08 altima coupe 2.5s - *Sold*
why not get an aftermarket double din?
elchingogon
I like the radio, but i want to make sure i dont waste my money buying something that will no be compatible. thanks for the reply though
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
Im not sure what the cost is on the OEM radio, but aftermarket might be cheaper and will definitely get you some better sound. Do you have manual or automatic climate control? (Or is that a dumb question for 2010 models?)
elchingogon
DJBeasy wrote:Im not sure what the cost is on the OEM radio, but aftermarket might be cheaper and will definitely get you some better sound. Do you have manual or automatic climate control? (Or is that a dumb question for 2010 models?)
Well I like the way it looks on the car plus i like the stearing wheel controls. It has manual climate controls. I can get one at a good price but I dont know if it will work or give me more headaches
spawn01
Car: 2008 altima coupe, 3.5 se
Had the same problem with my wifes 08 coupe after about the 2nd year we owned it. Radio worked fine, just could not see the display. It was covered under warranty. I would think that your 2010 would still be under warranty.
elchingogon
spawn01 wrote:Had the same problem with my wifes 08 coupe after about the 2nd year we owned it. Radio worked fine, just could not see the display. It was covered under warranty. I would think that your 2010 would still be under warranty.
unfortunatelly it isn't under warranty. I hope someone can shed some light on this matter so I can resolve my issues. Thank you for your reply Bud. I'll keep waiting to see.
Coupe12
Car: Nissan altima coupe. 2008, 2.5S
you can still use the steering wheel controls, you just gotta buy some sort of adapter.......
elchingogon
Ye I suppose I can get an addapter. I'll see what I will be able to find, thanks
DAAN.
Speaking of that ... can I put a 2010 radio into my 2009 altima 3.5 with everything but NAV on ?
DJ_B_Easy
elchingogon wrote:Ye I suppose I can get an addapter. I'll see what I will be able to find, thanks
Company called PAC makes the adapters for aftermarket to steering wheel control. Its all doable, go aftermarket for sure.
joebaye
Car: Black 2008 Nissan Altima Coupe 3.5 SE
elchingogon wrote:The radio on my 2010 Altima coupe's digital display is not working. everything else works but I cant see the LCD. I wanted to replace it with another from a 2010 sedan or with a Bose OEM radio from another car but I dont know if they are compatible. can I just connect it and they will work like the Original on the car? Ive found a few but they have different part numbers but look exactly the same. Please help,
Thank You
Sorry no one answered your question, I was wondering the same thing. I have an OEM Bose radio from a 2011 Altima Coupe(the one with the color screen and back-up cam compatible) but I have an 2008 Altima Coupe with Bose and want to know if it would be a straight swap before I tear my dash apart...? Thanks!
CJ2010
Car: 2010 Altima Coupe 2.5s
You should go check with the dealer and see if they can call the factory rep and see if he will cover it.
legend_217
Car: 08 Altima Coupe 3.5 black
For those who looking for a good steering wheel adapter. I strongly recommend Axxess. Absolutely no lag at all, it takes me 5 mintues to install and program, no resistors needed
elchingogon
CJ2010 wrote:You should go check with the dealer and see if they can call the factory rep and see if he will cover it.
I already called and asked a couplke of dealers and all the can say is buy the original or bring it here and they will sell me the one for my car. does anyone out there have an answer? it will be greatly apreciated. Thank You :confused: :gotme
jmann
Car: 2017 Mercedes GLC300 4matic
2015 Infiniti QX70 AWD
legend_217 wrote:For those who looking for a good steering wheel adapter. I strongly recommend Axxess. Absolutely no lag at all, it takes me 5 mintues to install and program, no resistors needed
QFT - I got mine on amazon for like $35 shipped. Go with axxess ASWC for sure.
flipragain
Car: 08 Coupe
My 2008 A/C OEM Bose 6 cd changer LED display is out. I CAN tell you that the 08 part number is
28185-JA110. On fleabay, parts pullers are showing 07-10 that this radio fits stock. I also know that Nissan dealers can get a refurb from Panasonic for a third of the retail price, not sure if they will sell it over the counter or not.
For the refurb, add RX to the end of the above part number.
elchingogon
flipragain wrote:My 2008 A/C OEM Bose 6 cd changer LED display is out. I CAN tell you that the 08 part number is
Thank You for the information
elchingogon
FYI!!!!!! Hey Guys I bought another radio with another part number and it works like a Charm. everything works on it and I was looking at the connectors on the back of the radio and they all have extra connectors for diferent operations I guess but It worked great. I asked the a few dealers if it would work and they said it was not going to work and that I should use the same as my old one for a prtty penny. I bought it at Fleabay for $75 + shipping
