2010 3rd tail light lens replacement
Helium2
Car: 2010 Nissan Rogue SL AWD
My 2010 Rogue has suffered a broken 3rd tail light lens, probably due to recent hail.
A quick call to the local Nissan dealer tells me the entire unit has to be replaced at a cost of approximately $145 (US) not including replacement labor. :mad:
I'm going for some silicone sealer to keep the water out instead.
Anybody have advice for a replacement for the lens?
How difficult is it to replace the whole unit?
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
Helium2 wrote:My 2010 Rogue has suffered a broken 3rd tail light lens, probably due to recent hail.
lights are all sealed. no lights' lenses can be replaced now a days.
Helium2
:bang :bang
So how difficult is it to replace the unit?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Helium2 wrote::bang :bang
$145 is high. Check out Courtesy Parts http://www.courtesyparts.com/nissan-rea ... 68865.html You'll have to look at the driverside door and look at the label on the lower portion of the door jamb for the correct color code. Most are either $38.75 or $77.50 (except the Orange Alloy Metallic, which is nearly $300).
Check out this thread for details on replacing the wing/spoiler. pic-s-of-rogue-with-spoiler-and-body-si ... 31-30.html As your replacing it, rather than doing a new install, it should be fairly easy, as all the hard work's already done.
Helium2
I have no spoiler.
I'm looking at replacing the 3rd brake light unit (apparently).
Rogue One
2022 Honda Pilot SE
Oops! Sorry, I misunderstood. :blush:
Ok, here's a youtube vid on how to:
[youtube]http://www.youtube.com/watch?v=ukUJ4EjJS70[/youtube]
Helium2
Thank you! :yesnod
sprocket
The P/N is 26590-1VK0A if I'm not mistaken, and it does sell for around what the dealer quoted you.
Your local junkyard aka auto parts' recycler might have a Rogue or two with an intact high mount stop lamp you can get for less :)
Helium2
The only thing that stops me from going to the junkyard is the mounting gasket gets butchered during removal. :frown:
I definitely do not want damp & dirt getting inside the hatch door.
Return to “Rogue Forum”
