2010 3.5sr 6 spd clutch noise
All things Altima Coupe.
battousii1991
Car: Nissan Altima Coupe 3.5 SR 6spd
Raceingline Y-Pipe
Injen Short Ram Intake
i have a 2010 3.5SR 6 speed coupe and i was just wondering if anyone has had problems with their clutch/transmission. On a rare occasion when i engage the clutch in first gear from a dead stop it makes this terrible noise like the clutch is slipping. i like to compare the noise to a bus or semi truck coming to a stop at low speeds and the brakes make the loud obnoxious sound. also when i push the clutch pedal in it sounds like theres flywheel chatter. anyone else have this problem?
RicerX
Car: '20 Titan Pro4X
It's going to be tough to get feedback on here for this, as virtually no one here owns that configuration.
I used to, and had the car for 44,000 miles before I had to get rid of it for something with extra doors. I never experienced anything like this. If you have less than 60,000 miles on it, your car is still under powertrain warranty, so if it is something dramatic, then a dealer diagnosis is the best route. Good luck!
