200zr crossmember
A home for 1983–1989 300ZX owners!
desertz31
Car: 1987 z31
will this work for rb26 into z31? what else would be needed?
http://www.ebay.com/itm/Very-Rare-Nissa ... 5a&vxp=mtr
desertz31
Car: 1987 z31
Nobody? :werd:
I need to know if this will allow for a bolt in swap
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
it should work for the motormounts, but the oil pan is a differetn story, if you are runnign the rb26 you'll want to getan rb20 oil pan as well, you'll have to modify the opil pick up and possible the rb 20 oil pan as well.
desertz31
Car: 1987 z31
he has a 200zr oil pan and pickup that I can buy with the mounts, will this pan work on the 26?
evildky
06 Nissan 350Z GT
well you sure can't use the rb26 oil pan, so you'll need one from an rb20 or rb26, the rb26 uses a dual sump and this will need to be modified no matter what you do, and I'm pretty sure this modification will require whatever pan you use to need to be modified as well, one fo the many reason's I like my L6 and VG's
Return to “300ZX (Z31) Forum”
