200sx with blown sbc 5.7
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
2 Black Lines
Car: Nissan 200sx S13 V8, R33 Skyline GTS-T, Stagea, Corvette C5
Hi Folks, just thought I'd say hi and post up a few pics (when I find out), of my s13 bodied supercharged chevy engined 5.7.
Basically i from Scotland and produced this with nothing to go on only some ideas and good knowledge of the cars.
Will post up some pics later.
The basic engine spec isEagle crankEagle rodsTRW pistonsComp cams hyd blower grind1.5 jesel rollersL98 small blockCorvette alloy headsBDS 6-71Bds Drive gearCurrently running 7psi boostMallory dist.Msd ignition.
Fully street legal and registered as a 5.7.
Oh and its the first and only one I know of in the uk.
matafied
Car: 1989 240 rb25det 1992 240 rb25det
nice!! lets see some pic's
2 Black Lines
Hope you can see this.
S133P3R
Car: 1989 S13 240sx
you missed a part of the html there^^lets see some pics of you garage, your quiver of cars is making me s***.
2 Black Lines
2 Black Lines
S133P3R
Car: 1989 S13 240sx
2 Black Lines wrote:
any pics of your other rides?
2 Black Lines
Np, will post them up in the correct place once I find it!
Btw had a look at what others have done, for there installs, mine has no cutting to the bulkhead and uses a std unmodified 1989 corvette sump (pan), tho the S13 subframe is sectioned and dropped 2" to accomodate the pan.
I've used a Driftworks outer track rod end conversion to alter the steering arms to eliminate the bump steer.
The only problem is the gearing, I've got a stock TH400 but with a 2900rpm B&M torque converter, and the standard back end with Vlsd ( on its last legs!) 3.9:1 ratio good on the strip, very silly on the road.
S133P3R
Car: 1989 S13 240sx
you drive that thing on the road?....just make a "hello, my name is_____" thread and post up pics of your cars in there... you will be welcomed with open arms. enjoy the site!
2 Black Lines
2 Black Lines
http://www.youtube.com/watch?v=Bgh3XS3SwZs
Modified by 2 Black Lines at 1:28 AM 2/21/2009
S133P3R
Car: 1989 S13 240sx
2 Black Lines wrote:The only problem is the gearing, I've got a stock TH400 but with a 2900rpm B&M torque converter, and the standard back end with Vlsd ( on its last legs!) 3.9:1 ratio good on the strip, very silly on the road.
Very silly indeed... is there links for videos on the strip?well i hope the roads in... umm, East Renfrewshire are long straight and open. do you have any problems with police in your area driving a car like that? what if any are the emissions laws in your area?
WDRacing
I'm not a big fan of the 6-71, I was thinking about the smaller 174. For up to 383CI it's good for 10 psi depending. But damn if that thing doesn't say Rat Rod. Very well done man...
With those gears and I'd venture to guess an instant 400 ft lbs of torque it's basically undriveable huh? I don't think silly sums it up...lol. If you can get that whore to hook up and not eat drive train components you could easily see 9's in the 1320.
So...you used the stock pan and dropped the subframe 2"? I suppose with as much as that motorset weighs you're not concerned with steering anyway. How is the daily driving as far as suspension and handling goes?
WD
Return to “Hybrids”
