Im new on this forum and im seeking your advice because it seems like all the best answers come from here
I just picked up my newly machined block and head from the machine shop. Everything was fine, but the machnist pointed out that the engine had been machined before...
Looks like the previous owner had spun the middle main bearing(with the collars?) and put in a set of new ACL STD main bearings.
Sounds good so far?:D The middle bearing had become loose in the driveline direction (timing cover -> transmission direction) and he had welded some bearing material to the side of it (i dont know IF that is even possible but thats what the machinist told me, ill post a pic of the bearing when i get home).
This weld has now caused a pretty deep score on the crankshaft weights (bearing suface is fine). The machinist told me that im just gotta usein the old bearing since its not damaged and change all the other bearings.
My questions are as followed,
Does the CA18DET have a rounded mark on the crank where the middle main bearing comes?
Does the bearing have some material on the sides to be tight enough?
What do you guys think about not chaingin one of the main bearings?
Or do I just have to find me a new/used crank?
Allso, i read on another topic that the oil pump doesnt need to be changed if it doesnt have scores inside. How do i check this? Pics would be greate
Thanks in advance,
Wolter
