pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Mon Dec 06, 2004 1:42 pm
Can you tell if the noise is comming from top end or bottom end?
The reason I ask, is if it is from the bottom end, it could be connecting rod bearings.
What octan are you using, if you use low octane, that would cause the valves to tick and possible detonation.
Also, if the temperature sensor is gone bad, it will cause the valves to tick due to the ecu to advance or retard the timing.
Keep us updated.
Good luck,
PULSAR GTR
Rafi
