I'm trying to run down a battery problem (battery is good and is fully charged, posts are clean, but car won't crank without a jump), and I'm kinda wondering about a grounding issue. The lug on my negative cable (highlighted in green on the diagram) that's supposed to go "TO BODY EARTH" is hanging loose, while the lug going "TO ENGINE EARTH" is bolted to the frame.
I can't make head or tail of the FSM, nor can I locate any diagrams that tell me where/what on the actual vehicle the two lugs on the negative cable should be grounded to. Does anyone happen to know what those lugs should actually be bolted to?
