2009 Versa Broken Mount
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
JoseIbarra
Car: 2009 Nissan Versa
See attached where this piece is broken and I want to replace it.
I think it might be 11350-EL00A Rod Assy-Torque but not sure of the part number I need to order.
It looks like something I can replace myself - the engine won't fall out if I start to undo things will it?
What is the purpose of a Rod Assy-Torque? I don't get the rubber bumper thing on the end.
What is the part number I should order?
Are third party parts okay to use like Amazon ($24.99 USD), RockAuto etc. or should I stick to OEM (looks like $98.49 USD)?
What are the torque specs for the bolts - I have a few torque wrenches.
Where can I read to be sure of torque specs?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Yep, that's the Torque Rod (colloquially the dog bone). Provided your nose and transmission mounts are both healthy, just put some support under the engine while changing it (I usually use a floor jack and 2x4 under the pan). Have a long prybar and a lineup punch handy to position the engine for reinstalling the fasteners.
JoseIbarra
So I would need to support the engine, right?
Unanswered questions:
VStar650CL
Technical Expert
JoseIbarra wrote:
Tue Dec 10, 2024 3:37 am
Yes, but only so you can get it lined back up again after replacement. There are no worries about the engine going anyplace if the nose and transmission mounts are healthy.
That looks like the right number, but it supersedes to an EL00C. Either part number will work. There's nothing wrong with eBay or Amazon parts in this instance. They may be lower quality, but with an engine mount, that just means you may replace it again sooner.
It's a harmonic weight, it helps absorb vibration. That's one purpose of a torque rod, but the main one is to absorb "twisting" motion of the engine.
Nissan puts almost all of their torque specs into the exploded drawings. In this case, both bolts for your dog bone are 103 lbs/ft. See EM-195 here:
https://www.nicoclub.com/service-manual ... 9%2FEM.pdf
BRRC
Car: 2011 Nissan Versa , 2011 Nissan Sentra and a '23 Nissan Sentra .
It's a 20 min job . Done it already , make sure you jack de engine before starting .
Return to “Versa Technical Discussions”
