altimacape »
https://forums.nicoclub.com/altimacape-u249083.html
Wed Mar 11, 2015 1:18 pm
I just purchased a mint 2009 Nissan Altima 2.5 se. The only issue when purchasing was that the tpms light was one. I got a great deal, and thought it would be an easy fix--not so. All tires are at 32 psi, and have been filled with nitrogen (green caps). When the car starts the tpms light flashes then stays lit. I've taken it to 2 different garages, who used the tool to check each wheels' sensor and reset light. The light will then stay out for about 30-40 kms before it starts flashing again. I asked the last garage to simply tell me which wheel sensor is bad, which they said they had the ability to do, but each of the sensors always comes back as working. I'm desperately trying to avoid the dealer due to the higher cost. However, ther last garage recommended changind all four sensors, which is rediculous. How can I determine which sensor is bad?
